sin off pi (3,14159) equal a 1,22465
why sin off pi is equal a 1.22465  when is 0 the same ocurr with pi x2 6,283 is equal a 2,44 when is 0
i use sin example to control it
(1,252 Views)
It sounds like the classic DEG/RAD issue, Maybe post your code to elaborate on this issue.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(1,247 Views)
This is a display format issue.  You're looking at the number in scientific notation.  Right click the indicator -> Display Format and change to floating point.
aputman
(1,234 Views)
thanks you
(1,201 Views)
the precision of floating point numbers are limited. Pi and 2pi cannot be represented exactly as a floating point number, so sin(pi) and sin(2pi) can't be zero.
sin (pi) is something like sin(3,14159265358979311) and that's not zero.
(1,171 Views)
