sinewave output distortion
I used sine function inside the while loop and generated continuous sine wave with sampling frequency 10000Hz.
The output I connected to the graph chart and loudspeaker.
The graph chart looks fine and I have output sound from loudspeaker, but it is not sound like correct frequency I want. For example 100Hz, 300Hz, 500Hz.
What is wrong in my code?
Thank you
(4,341 Views)
What do you mean that it doesn't sound like the correct frequency? What kind of hardware reconstruction filter are you using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,315 Views)
You are writing a single sample in a loop that spins as fast as possible. You have zero control of the output frequency.
(4,300 Views)
Hi Mike.
I am using NI myRIO-1900 analog out port. It looks like multiple frequncies or some kinda distortion, not sure.
(4,296 Views)
Hi Dennis,
Yes, I think that is the problem. How I can solve the problem. should I use timed loop instead?
(4,294 Views)
Here is the timed loop sine wave. The sound it much better. But there is some background noises.
In youtube there are some 1000Hz test sounds, and when I play them with loudspeaker, the sound is pure, and only one sound with one frequency. When I use my code, the sound had some other elements. not sure what it is.
How I can generate pure sound with single tone without background noises?
Thank you
(4,283 Views)
Do you have a hardware filter on the analog output? The output from the DAC is not the smooth waveform you see on the graph. The output changes by discrete steps. Try Googling "reconstruction filter".
Mike...
LabVIEW Champion
(4,254 Views)
