single boolean to array boolean
Hi everybody,
I'm working on a project about the Modbus using the 'Modbus on desktop.vi'. In the Vi, the type of 'coil values to write' is a boolean array. I want to change it into a single boolean. is it possible? I include a screenshot of the block diagram and front panel.
thanks.
(3,910 Views)
Accepted by topic author Erickmsaputra
You can just use the build array function with a "single boolean".
boolean.pngThis will give you an array with one item.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,890 Views)
hi stevem181 thanks. it helped me a lot!
(3,882 Views)
