single channel and muliti channel waveform
Dear all
I have saved an tdms format data. This data includes 4 channel of measurement with the time information.
Now I would like to plot these channel out.
The question is that
1. how can I plot only one channel instead of all 4 channels.
2. how can I plot one channel result from two tdms file such that I can compare these two result?
for example, I attached test_12-07-03_1130 and test_12-07-03_1133, two files of measurement.
I want to plot channel 1 (or 2 or 3 or 4) from these two files into one plot.
Thanks in advance~~
(2,235 Views)
Thanks for your posting on this forum. What you want to do is possible. For your first question I have to say that you just need to define your channel in the input of the TDMS Read function.
You can in its input put the name of the channel(S) which you want to display.
For your second question I can say that you need to use the same structure of the first step and plot the other channel and compare them together.
The best hint is to use the example of the TDMS file which you can find in the Example Finder of LabVIEW.
You can also find them by going to any block Diagram and go to the TDMS Read function. Then by selecting Ctrl+h you can open the help file. Then click on Detailed Help to go to its all information. Scroll down to see all examples.
I hope this helps and if you have any question don't hesitate to ask.
Hossein
(2,202 Views)
