single cursor for multi plots
Hi All,
In My application i am using a XY Graph having multiple plots.
My Application is to show X & Y Value of each plot with the same vertical cursor.
Can anybody suggest me how to do it?
Thanks & regards,
Vipin Ahuja
(3,097 Views)
vipin_ahuja101@yahoo.com wrote:
Hi All,
Thanks & regards,
Vipin Ahuja
So you want all of the Y values at a given X. Is this what you are asking?
Tim
GHSP
(3,083 Views)
Using property node you can set the active cursor to 0 and the cursor mode to 2 (multi-plot). Define a Graph -> cursor move event and extract the cursor x position from the Cursor property of the event data node. Use this X value to find the corresponding Y value of each plot.
Ben64
(3,079 Views)
Yes Exactly i want this.
(3,069 Views)
