single precision matrix multiplication
another approach:
This creates one more memory buffer, but works without case structure Smiley Wink
Message Edited by GerdW on 04-08-2008 05:22 PM
Message 11 of 17
(2,149 Views)
Well, we don't need 2D for the vector. 😄
Message Edited by altenbach on 04-08-2008 08:36 AM
Message 12 of 17
(2,144 Views)
Hello Altenbach,
thank you very much for the algorithm. I have tried it and obviously it works, but unfortunately it seems not to be useful in real-time. I have verified the performance and it is about 5-times slower than the standard matrix multiplication in double precision (see attached file) Smiley Sad
Lukas
Message 13 of 17
(2,139 Views)
Thank you GerdW, but it is still much slower than LV built-in matrix multiplication function. I am afraid that there exist the only one solution. Program it in C, compile in to DLL an link it into LabVIEW (for now, I can't do it...)
Lukas
Message 14 of 17
(2,130 Views)
Most modern processors do double precision arithmetic about as fast as single precision (both are single-cycle or multiple operation per cycle operations).  Your only advantage in using single precision is probably in memory handling.  Modern processors can also do a lot of the matrix math in single operations (SSE2 and above capable processors can do this in double precision, MMX is integer, SSE is single precision).
Take home message - you probably will not get much speed out of this exercise.
One final note. Although I am an NI employee, I do not work with the math/analysis team so have no knowledge of the internal structure of the matrix operation primitives/VIs.  I develop applications in LabVIEW.
Message 15 of 17
(2,109 Views)
I have to try it, because this multiplication must run faster. I can't see any other solution (except buing a new processor for my PXI)
Message 16 of 17
(2,102 Views)
Lukas,
What is your LabVIEW version and OS?  I may have a solution for you.
-Jim
Message 17 of 17
(2,092 Views)
