single tone amplitude measurement
Hello every one...
 Plese explain me about TONE MEASUREMRNT VI in labview.How it provides freequency and amplitude from the input signal...
                          Thank you
(3,072 Views)
Accepted by topic author hanumeshbujji
Check out this posting.
The power point presentation explains the used algorithm in details.
(3,030 Views)
Thank you...if you have any information regarding please share...
(2,996 Views)
Well the code is now public so you can try to look at it (you can tell it was written in 1999 and developed on a 800x600 monitor Smiley Very Happy ).
Only difference from the algorithm described in the power point presentation is, that the code also corrects for estimated errors caused by spectral mirroring around DC and Nyquist. This improves accuracy especially at low frequency and it performs much more accurately all the way down to two sine periods.
(2,993 Views)
