Showing results forĀ
Search instead forĀ
Did you mean:Ā
size array indicator width
Is it possible to autosize the width of a string array based on the maximum  length of the strings in all of the elements?
(3,578 Views)
Hi id,
yes, that's possible...
Spoiler
- Check the length of all strings, either by StringLength or by GetTextRect
- set the width of the string indicator to fit the longest string using a property node
(3,559 Views)
that works for the individual element but the array indicator that contains the string doesn't resize automatically to fit the new width.
(3,550 Views)
Accepted by topic author id
Hi id,
for me the string array indicator changes the width when I set the width of the string element!
Show your VI to spot the problem...
(3,545 Views)
you are correct.  I had a misplaced reference...thx
(3,528 Views)
