skip frequency / Frequenz überspringen
When the amplitude reaches 0.25, it should be continued to the next frequency and the sound should not be played at this value.
The problem is:
When I only set "=0.25" without the loop counter one frequency is skipped. So I used, like you said, the loop counter. Now the frequency is not skipped, but at the value of 0.25 a sound is played:
1) When i trigger the event when the loop counter is 0, the sound is played only on the right channel of the headphone
2) When i trigger the event when the loop counter is not 0, the sound is played  only on the left channel of the headphone
The solution is:
1) A sound at 0.25 is played, but on both channels
2) No sound is played
When the first solution is used, a frequency is skipped like before. So it make sense to use the second one, like mentioned in the first row.
Best regards
DOM
Message 11 of 13
(419 Views)
You say no sound should be played at amp 0.25.
So you could:
- when amp = 0.25 overwrite it with 0 (independent of the loop counter i)
- when amp = 0.25 AND i=0 trigger event
Message 12 of 13
(414 Views)
I think we understand each other somehow wrong. Smiley Sad
When I overwrite the amp with 0 (independent of the loop counter) one frequency is skipped and this was the problem at beginning.
When I trigger the event when amp is 0.25 and loop counter is 0, no frequency is skipped, but as i mentioned in my last post, a sound is played, but only on the right channel.
How can I play the sound on both channels (better its played right than wrong) without skipping a frequency or how can I make also this amp to 0?
Best regards
DOM
Message 13 of 13
(411 Views)
