skipping first step of array
I have an array feeding into a for loop. If i have 2 steps, it will only activate the first step for a half second or so and then continue onto the second step and complete the second steps full responsiblity.
Message 1 of 9
(3,756 Views)
show your VI
Message 2 of 9
(3,754 Views)
I am running a pump that will infuse/withdraw at a certain rate until the certain volume is acheived. It starts the motor of the first step for a quick second then moves onto the second step and completes that step.
Mike
Message 3 of 9
(3,750 Views)
I don't have the drivers, but my guess is that you are running into an error in your first iteration.  Use a shift register to keep your error through the loops and see what error you have at the end.
Message 4 of 9
(3,741 Views)
Can you show me where to put the shift register please?
Message 5 of 9
(3,737 Views)
Also, if I just assign one step then it will go through the first iteration.
Message 6 of 9
(3,729 Views)
Message 7 of 9
(3,717 Views)
For OP: one correction to the above snippet: Wire an empty array constant to initialize the shift register. Otherwise, the shift register's value will be "remembered" when the VI is run again. Of course, this is a fundemental principle that allows the creation of functional global variables, and their super-charged friend, the Action Engine.
Message 8 of 9
(3,705 Views)
Discussion on this project has been continued on another thread.
Message 9 of 9
(3,700 Views)
