slide bars slow EVERYTHING, I dont understand!!!!!
Yes, there are a lot pf problems with the current (unmodified) code, but I don't understand the original problem of slowness. On my 4 year old Laptop (core2duo) I can easily reach a loop rate of <50ms, so maybe something else is wrong on your machine.
Actually thank you for letting me know, It made me a bit astounded and urged me to investigate. Indeed, there was an outdated video driver. Although I ran recently quake 3 with a decent quality it seemed to work fine in 3D, but not in 2D, so I was late to find that oute. After updating I got drammatical boost in the speed of redrawing. So far so good, yet I still found it creepy with these bars. Then I actually replaced them with the boolean array custom pipes, and thats quite a funny thing to look at Smiley Wink Still it was little choky, and I experimented with synch-dysplay. It made it more stable but lowered the cycles significantly. And then again I found a little lag when it gets to the stack of 1st and 2nd bars, these two bars, they were simply overlapping just a little, but nevertheless proved too to be ruining all the performance. Then I placed just about 1mm gap in between, and then miracle had happened, it finally ran at a stable rate.Thanks everyone for helping me in this thread, and I will attach the current version, with that cute thing and fixed bugs:
Message 21 of 21
(339 Views)
