slider indicator
     I already have a graph on the front panel. I tried to use annotations in graph it just displays the amplitude of the y-axis but not constant values. I know using array indicators would do the job but the problem is that the values are updated so fast that visualisation or change of values of values are difficult. So, i thought if there is some scale kind it would be helpfull to display.
Message 11 of 19
(2,351 Views)
you can show these values in 1d array.................
Message 12 of 19
(2,348 Views)
Yes its possible to show in 1d array, But the value change is so fast that all the indicators give the same output. I can't give a delay also becos it delays the entire program and runs really slow. It would be helpfull if it is a moving data just like a graph scale.
Message 13 of 19
(2,343 Views)
None of what you are saying is making any sense. You just threw in some off-the-wall reference to annotations and say it would be helpful if the data updated like a graph but the only reason you cant use a graph is that you already have one.
Message 14 of 19
(2,326 Views)
       I have  used annotations in the graph, it can be seen in the attachment. But the problem was able to display only amplitude of y scale, if i give constant values as input it would stuck only in that particular constant and print nothing after constant value.
Message 15 of 19
(2,319 Views)
You can display whatever you want as annotations. If you don't show your code and provide some details, no one can help
Message 16 of 19
(2,313 Views)
         Ok, Is it possible to display a set of constant values on the graphs? If so how to do it please do tell me?
Message 17 of 19
(2,310 Views)
Accepted by topic author jay0909
A set would be defined as an array and whether the values in the array are constants or dynamic is irrelevant.
Message 18 of 19
(2,304 Views)
      Thanks a lot. It worked !!!!
Message 19 of 19
(2,300 Views)
