slow communication
hello
  Am using lab veiw to connect PLC, the problem am facing was that boolean 1 button i press the boolean button 2 shows late result as shown in video attached
am using modbus tcp communication
boolean 1 is an start button
boolean 2 is an output of my controller, output result is good but the indication on labview is very slow
(3,613 Views)
Hi Sami,
the problem is either in your LabVIEW code or in the PLC code. You need to find for yourself!
Attaching a video to show a problem is nice. But it's senseless to (try to) debug code without code…
(3,601 Views)
please see attached files
(3,595 Views)
plc is giving instant output but this output indication on lab view is late as shown in video
On button (boolean 1) giving instant indication but the boolean 2 button (plc output indication) showing late result on labview
(3,591 Views)
Hi Sami,
I cannot open your LV2019 VI but I guess you are using some OPC connectivity option.
What do you think how fast is this communication? There's a lot of request-and-answer stuff done in the background - and this will not respond within milliseconds…
(3,587 Views)
hi
yes am using opc server
i think output indication on hmi comes 200 miliseconds late
(3,581 Views)
