small data loss
Hello everybody
I developed a code to be able to stop the acquisition in finished mode with a stop button and it works quite well but I noticed a small loss of data
Why do you think there was this loss? and is there a way to fix this problem?
thanks in advance
Message 1 of 11
(2,317 Views)
here is what I did on labview
Message 2 of 11
(2,313 Views)
Hi Amelie,
Please define "small loss of data"!
I guess you compare the number of samples read vs. the number of samples configured in your "Finite Samples" task!?
So you stop acquisition before the task has finished and still wonder why you read less samples than configured!?
Message 3 of 11
(2,298 Views)
2 acquisition channels at 25 kHz for 1 s I only read 24833 samples
yes I compare that but I have a loss even when I don't stop with the stop button
Message 4 of 11
(2,285 Views)
Hi Amelie,
So you miss 67 samples?
  1. In the last iteration of the loop you read the number of available samples
  2. You read that amount of samples from the buffer.
  3. You determine the "task finished" condition.
  4. You stop the loop when DAQmx says "all samples acquired" at step 3.
The problem is: between step 1 and 3 will be a (small) delay!
When you read the number of available samples (at step 1) the task is not finished yet, but milliseconds later (at step 3) it has finished. Your "loss" relates to this delay (67 samples / 25kS/s = 2.7ms)…
You may iterate the loop one more time or you may read the remaining samples from the buffer after the loop…
Message 5 of 11
(2,262 Views)
How can I iterate the while loop in my case?
can you put me on a trail?
I tried to put the while loop in a for loop I set the number of iterations as 2, the problem is solved but now if I want to stop I have to press the stop button twice
Message 6 of 11
(2,240 Views)
Hi Amelie,
You want to stop the while loop when
  • an error occurs
  • the STOP button is pressed
  • all samples are acquired (this is different to "DAQmx task finished" as I explained in my previous message!)
Message 7 of 11
(2,223 Views)
Try to call the DAQmx nodes in a different order.
In the while loop, first call "DAQmx Is Task Done?", then query "Available Samples Per Channel" and then DAQmx Read.
Message 8 of 11
(2,211 Views)
Or easier, just tell the Read to read the buffer size of samples and the loop is unencessary.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 11
(2,207 Views)
Well, OP didn't say it in this thread, but wanted to stop the read operation even if not all samples are taken in this thread https://forums.ni.com/t5/LabVIEW/stop-acquisition-in-finished-mode/m-p/4376436#M1286823 only yesterday 😎.
Message 10 of 11
(2,199 Views)
