small in big
I have a big vi in labview 6.0. When I print the prpgram, some sequences contain code that are too small. Can I increase the size of the contents in the sequence without changing the size of the sequence frame in labview 6.0? I do not want to change the size of the sequence because it might corrupt the program. The vi is attached.
(2,670 Views)
you can capture the image of that sequence (only the portion you want) and print out the image.
or you can copy that code into a new vi with a new sequence and print the new VI.
-Joe
(2,659 Views)
