smart array
Can i get a witness! J/k
I have this smart array which automatically selects its dimension size by the number of times the for loop runs.
The issue is that i want to fill up each row with the data in column 2 in order from left to right according to the dimension of the array.
So far i am getting the same data in each row, i don't want this.
How can i succesfully do this?
Gracias en Adelantado!
(2,980 Views)
The description of what you're trying to do is somewhat difficult to understand.  I have no idea if the VI I made even gets close with what you're trying to do but it should give you some ideas at least and perhaps you can look at it then comment more on the specifics of your problem.
Here are a few pointers for you though, based on your code.
  • The first thing is that you have a numeric wired to the for-loop index while the loop also has an indexing input.  Keep in mind that the indexing input will always limit the number of iterations that the for-loop actually executes if the size of the input array is smaller than the numeric wired to the for-loop index.
  • The second thing is that you are initializing a 1-d array inside of the for-loop and then indexing that array when it leaves the for-loop so the output is a 2-d array.  Generally speaking, it is probably better to initialize the array only once without using the for-loop.  By dragging the input terminal down on the Initialize Array function, you can initialize a single 2-d array to start with.  This saves time and memory  as compared to initializing a bunch of 1-d arrays and then using them to build a 2-d array
  • The third thing is that when you initialize an array, it will be filled with all of the same value that you initialize with (part of the problem you were having I believe).  The solution is to intialize a zero-filled array to the size that you would like, then fill sub-sets of that array with the values you would like to place in it.  A subset might be a particular row, column, part of a row, part of a column, or a set of cells spanning multiple rows and columns.  This is accomplished using the Replace Array Subset function.
I have modified your VI and attached it for you to look at.  Like I said, I'm not sure if it does really what you want it to, but it should give you some ideas.
  • First, the row and column dimmensions of the input array may be obtained using the Array Size function and then indexing the array of sizes.  For a 2-d array the Array Size outputs the [Number of Rows, Number of Columns].
  • Using either the number of rows or columns as you desire, you can size your output array correctly.
  • Using the Numeric input value, you can also size either the rows or columns to be a particular dimmension, without needing a for-loop.
  • Once the array is initialized, you may replace subsets of the array with data from the input array.  For my example I transposed the columns of the input array into rows, and then replaced the rows in the output array.  Using the indexing inputs to the Replace Array function inside of the for loop, the data could be placed anywhere within the output array.
(2,970 Views)
