smoothening of graphs
hi,
i am usingt labview 6.0. i get the graph readings. but it draws straight lines connecting two points and giving a graph with pointed corners. i want to get a smooth graph. does anyone know how to get it ???
(2,790 Views)
Probably you have small number of samples.
In this case you can make interpolation of your graph.
Use Mathematics/Curve Fitting/General Polynomial Fit.vi
(2,790 Views)
I think nchernin is right. The graph cannot interpolate points in between data points to give you a spline or non-pointy curve. If you want this, you'll have to add those points yourself.
(2,790 Views)
