sms error
hi...i am trying to send email using labview.finally i get one example from ni site..
but i have problem to run this .vi file..the error exist..i am using LV 7.1..could you help me to solve this problem..
thannks...
regards,
firdaus
(3,191 Views)
Duplicate.
___________________
Try to take over the world!
(3,184 Views)
Hi firdaus,
tst, as always, is spot on finding your duplicate post. It should be mentioned that you should never post the same question multiple times in a discussion forum, as it results in several people expending resources to return the same answer. Please refrain from doing this in the future.
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,172 Views)
Actually, in this case finding the duplicate post was very easy because both threads were together.
I think this was just an accident since both threads were identical and posted at the same time. We have seen much more than once that duplicate posting happens with posts (the infamous "tab and post" bug), so I assume it can also happen with threads.
___________________
(3,167 Views)
