smtp email send file
I'm trying to send an email with an attachment using the smtp email send file under LV 7.1
When I run the vi the following message appears: " 500 syntax error , command unrecognized. For example , the command line might be too long".
The same if I use the email with data.vi example.
Thank you for your help.
Andrés
(3,366 Views)
Hi Andres,
this is a link of a NI document that it can explain what causes your error:
If you don't solve the issue with the document information you could attached your VI to reproduce the problem.
Regards
MarcoC
NI Italy/Spain
(3,344 Views)
Hi Marco,
I've tried your suggestion and the message on the reply string is confused for me: " 220 ctsmtpout.frontal.corre o ESMTP Service ( 7.2.056.6) ready ".
I attach the vi that I'm trying to run. It is the one on the LV7.1/examples/comm/smtpex.llb        EMail with Data.vi
Best regards
Andrés
(3,330 Views)
Hi Andrés,
I've used your code and all has worked fine, I think that the only thing we have different is the "Mail Server", so I think that your problem is due to it. What kind of a "Mail Server" you are using?
Try to use a Mail VI without attachments ("SMTP email Send message.vi"), does it work fine with your "mail server"?
Regards.
MarcoC
(3,315 Views)
Hi Marco,
I tried also the vi that you mention and it is the same.
I think you are right. The problem must come from my smtp server. It needs authentication and I've seen that smtp vi's don't support that kind of servers.
But I don't know how to solve that because every smtp server should run under authentication , in other case you are wide open to the world.
I would be grateful if you could give me a suggestion ( may be a solution ).
Thanks a lot for your answer.
Best regards
Andrés
(3,273 Views)
