01-18-2007 05:53 AM
01-19-2007 02:55 AM
I can give u a link where there is an example about how to acquire with a webcam:
http://forums.ni.com/ni/board/message?board.id=200&message.id=1121&requireLogin=False
Hope that helps,
01-19-2007 03:26 AM
Hi Jaime,
Thanks you for your help. I was doing things right. The problem has been fixed. The only thing I've had to do is to change the configuration of the image acquiring, to "555 RGB 16" and the image has turnned to normal. It also work in RGB 24, in every resolution option.
Thank you again,
Alfonso.
01-19-2007 03:39 AM
01-19-2007 03:52 AM
good to know that worked 😉
01-19-2007 05:12 AM
Yes, as you can see in the attached photo, the VIs run fine in my computer. The webcam I'm using is the most basic one (from logitech quickcam series).
I've tried Ivision from the website you mentioned, but a license is required. The thing is it doesn't matter becase the b/n image is enough to what I'm asked to do. I'll try the option from NI when I have time. I'd like to know a bit more about imaging in LV, but first I have to finish work. ![]()
Thanks for your attention
Alfonso.
