solidwork x64 and labview 32 bits compatibility?
Hello community.
I'm with a project where I want to make the connection with Labview 32 bit and 64 bit Solidwork to control motors with LabVIEW, I have been following many tutorials and I get to create everything you need but when you run the VI does not move nothing SolidWork thousand times and reviewed the steps and is desesperate. Ruling out any option and I wonder if these two shows are 32 and 64 bits can be the cause of not getting the communication with these two programs. I hope your help. regards
Es un placer echar una mano siempre( Base de una sana convivencia). Si mi respuesta te sirve por favor agradecemelo con un Kudo 🙂
Un especial saludo a mis hermanos latinos. Un mundo mejor es posible.
Message 1 of 1
(2,478 Views)
