solve 4 DOF differential equation
Hi, sorry my last message was just not completed....!!!
I am trying to simulate  a 4DOF model . I have been doing my entire project using Lab view; and my advisors say MATLAB coding is easiest to simulaye the model.
Plese any advices on how to simulate this model using Lab view?? iam completely lost!
I have 4 equations ans i have also arranged them in state space format if it would be useful... pls see attached document
any advice appreciated...
regards,
ruser.
(2,452 Views)
Hello, ruser!
The simplest thing to do here is to use the LabVIEW MathScript Node. This node allows you to run .m scripts from within LabVIEW, so you can integrate new MatLab code (which yes, would be easier to write for your application) with your existing LabVIEW code.
There is another discussion forum that deals with a similar issue (take a look at the third comment down, from GrantM):
Using LabVIEW MathScript
If you need more information on actually using the node, take a look at the following NI Developer Zone Article:
Using the MathScript Node
If you have more questions on this, please let us know.
Thanks!
Will Hilzinger | Switch Product Support Engineer | National Instruments
(2,426 Views)
