[solved] FPGA Compiler - NI 9074 and Xilinx ISE 10.1
I tried to compile FPGA code on a NI cRIO 9074. According to the compability list by NI Xilinx ISE 10.1 should be used with LV2016. This gave the following error:
"The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state."
The solution to this problem is to install ISE 14.7.
Message 1 of 1
(2,777 Views)
