solving a complicated equation
Hi, I have a problem. The equations goes like this,
Yn=TAN(x*T/2)-S/(x*D) where T, D, and S are user inputs. and n indicate nth root.
Then,
delta = an equation that involves the summation of Yn
For now, I can make the user to input the Value of S to get delta. However, I need to make the program able to calculate S when the user know the value of delta. Do anyone any suggestion?
Thank you in advance
(3,146 Views)
homework?
(3,134 Views)
An equation that fits on a single line is not complicated. 😄
Are the values real or complex?
If you have a VI that calculates delta(S), and the function is well behaved, you could use Newton-Raphson to calculate S(delta).
(3,130 Views)
And if the function isn't well behaved you can always whack it across the nose with a rolled up newspaper.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,110 Views)
