some questions about onboard progam
HI everone
It says that in ni-motion Each onboard program gets a default time slice of two milliseconds, after which it relinquishes control of the processor to the next onboard program or housekeeping task.what does this mean? a onboard program get 2ms time slice and it executes
once or several times  but how long it has to wait to execute again.in this case i wonder if the onboard program has determinism and if it can implement precise timed loop.Thank you !!!
(2,390 Views)
This thread appears to be a duplicate.  The response to the other thread, located here, should answer your questions.
Jesse D.
Applications Engineering
(2,370 Views)
