sort out array data as number order
Hello all,
Read a txt file get a lot of data TestNumber,SiteNumber and change_value.I want to sort out array data SiteNumber as refer,how to handle that,thanks in advance!!
(2,545 Views)
Looks like you're working with the Site-Site offset file of TSM, if you would like to see the values sorted, you can open the txt file in Excel and use the sorting/filtering features of Excel.
Santhosh
Soliton Technologies
(2,535 Views)
Accepted by topic author Sam.Huang
Here's a quick example:
It probably would help to streamline the data structures a little bit.
(2,505 Views)
Do I detect shenanigans?
(2,474 Views)
Wiring is fine, We just got some overlap after I moved the left FOR loop around. Did not notice the cosmetic problem.
Here's the same slightly shifted around:
(2,460 Views)
I thought it was a hidden feature, "sourceless data!"
(2,456 Views)
It is so useful, thanks a lot.
(2,434 Views)
