sorting Constants inside cluster
hello everyone
i have a lot of constants inside a constant cluster
i have tried this :
https://forums.ni.com/t5/LabVIEW/Sort-elements-in-a-cluster-in-alphabetic-order/td-p/3649743
but the problem i couldn't find out where to get this cyan, and if it works the problem i have every time to convert the constant cluster to control to convert the names then back to constant, anyway when it works also good
thanks very much
Message 1 of 13
(6,390 Views)
Hi MJDGH,
to sort cluster elements alphabetically by their label they need a label!
To create a cluster with nice labels I recommend to create a typedefinition of your cluster (with all elements having a descriptive label).
Then just drop that typedef onto your block diagram to create a cluster constant with elements having nice labels.
What is all this good for? Why do you need to sort cluster elements programmatically?
Message 2 of 13
(6,384 Views)
you need to create type-def cluster to make it work. right click on the cluster control, select make type-def and save the control. Use the saved control in the solution you found on the other thread.
bp
Message 3 of 13
(6,381 Views)
sure i have a label for each variable inside the cluster but the problem is i am using these names in many places in the program
its not possible now to add more than one cluster and i have a lot of variables i want to access them faster when they are by alphabetical order.
if i made the constant as type def then how to order these inside it ?
Message 4 of 13
(6,369 Views)
Hi MJDGH,
when you want to access "variables" by their name I recommend to use VariantAttributes (inside a FGV)!
Message 5 of 13
(6,360 Views)
can someone tell me how to get this element inside the link where to get this vi !
Message 6 of 13
(6,355 Views)
Hi MJDGH,
what is "this element"?
(Are you talking about my link? Darren talks about VariantAttributes…)
Message 7 of 13
(6,346 Views)
Hi MJDGH,
You can find the element in 'vi script' that are not visible by default. To activate it you click on : Tools, options, Vi server, Vi scripts and you check 'Show function, property ...'. You should now find it in your LabVIEW.
Or can simply use the fact that your link show a snippet, which means that you can drag it in your code to directly get the whole code shown in the picture.
Message 8 of 13
(6,341 Views)
hi mjdgh
are talking about the subvi in your link, that seems like third party toolkit. you can also create yourself one, i have attached a sample .
edit:attachment
bp
Message 9 of 13
(6,338 Views)
Hello
can someone please explain how to set the VI in edit mode
because i got this error:
LabVIEW: (Hex 0x431) This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
Message 10 of 13
(6,316 Views)
