sound and vibration
1) I built Source Distribution in LabView2011.
Mistake occurs: Error Copying files. Source c:\Program Files\NI... anstat.mnu. Unknown LLB File Type.
When I used Labview8.6 the build successful.
2) In Sound And Vibration Assistant I do following:
1 Add Step - Run Labview8.6
2 Select LLB file, then select my vi.
3 In the field "Input signal" I can choose only one channel. Fields "All elements" and "Define Subgroup" are not active. Why?
When I opened LW2011 VI without building Source Distribution these fields are active. Please Help.
(2,380 Views)
Hi Irafka,
For the "Unknown LLB File Type" you receive, I have only come across that issue for the older LabVIEW versions. As in, I would expect that message to come from your LabVIEW 8.6 but not your LabVIEW 2011. Below I have provided a link to a Knowledge Base that discusses the issue and a few possible work arounds. Would it be possible to get a screenshot of the Sound and Vibration Assistant you are seeing, specifically containing the 'All elements' and 'Define Subgroup' activity?
http://digital.ni.com/public.nsf/allkb/051f1533145089a1862578b80060d93b?OpenDocument
-Jake B.
(2,345 Views)
