sound and vibration
Is there an installation download available for the Sound and Vibration Assistant 6.0?  If so, where can I find it?
(2,987 Views)
Hi JHess,
the Sound and Vibration Assistant is installed with NI Sound and Vibration Measurement Suite and NI Sound and Vibration Toolkit.
You can download only the most recent version from the site that is 7.0.
You can download this version at this link and use it in evaluation 30 days.
Serena M.
(2,974 Views)
Thanks Serena.  I purchased the Sound and Vibration Assitant last year.  Between then and now the install disks were misplaced.  I would like to install the sofware on a new PC however my serial number is not compatible with the latest release of the software, hence my need to download the previous version (i.e. the version that I purchased).  Any suggestions?
(2,966 Views)
In this case you should contact the technical support of the branch where you have purchased the toolkit and they will help you.
Serena
(2,948 Views)
