sound file write
I am taking sound input from mic and writing it in a wav file (using example Sound Input to file).
but when i feed the signal from function (signal) generator greater than 1 V then the recorded wav file shows clipping in the example read sound file to chart.
Shrek
(2,985 Views)
 Shrek
Clipping will occur then you go outside the AD converter voltage range. So what did you hope to see from your test?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,980 Views)
