sound output
hi! I am working on acquiring signal using labview. I acquire sound signal using a commercial microphone attached to my computer soundcard then using labview, i can view the signal, the frequency and save the data.
However, I need to convert this signal to sound file so i can hear it again. I did not record while i perform the test thus i rely on the data i saved (*.lvm form).
At my capacity to write programs ( Ialways use express), can someone help me?
I attached is an example of the saved signal i converted to txt file
(3,123 Views)
Something like this:
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,109 Views)
This is so helpful and it worked with what I need.
Thank you so much.
An labview user here and just doing what is being asked even if I dont know if it works.
Thanks again.
(3,051 Views)
