sound pressure spectra with SVT
Hey all,
I have a project which I have been having a bit of trouble implementing. I'm performing several measurements at 48kHz/24Bit of some sound events. My requirement are as follows for sound pressure spectra analysis.
  1. 500 - 20 kHz frequency bandwidth with a 25 Hz frequency resolution.
  2. Peak  Hold  averaging  with  50%  overlap  processing  and  Hanning  windowing  applied  to  the time records.
  3. Anti-aliasing filtering.
  4. A - weighting.
I have the sound and vibration toolkit and have implemented as follows:
1. Read wav
2. Convert from Volts to dB via SVL Scale Volts to EU.vi. (I used a calibrated signal of 94dB at 1kHz to find my mic sensitivity).
3. A-weighting using SVL A,B,C Weighting Filter.vi
4. Peform analysis using SVL Zoom Power Spectrum.vi.
Few Issues:
  1. I dont know how to implement the Anti-aliasing filter.
  2. Is the method I have used ok with measuring sound spectra? Or should I perform the FFT then convert to dB?
  3. I have tried to implement the same analysis using Matlab and although I get the same FFT profile, my dB levels are different where the 16kHz noise is almost the same level as the 8kHz noise? Not sure what is happening there, but I want to concentrate on using LV for now.
I dont have any guidance available or experience with this sort of analysis. I have trialed my program out on a sample wav file which has two separate distinct noises events, one at 8kHz and another at 16kHz. My FFT is showing that the 16kHz is a much higher sound level (95dB) than the 8kHz (80dB) but when I listen to the wav via a pair of studio monitor speakers, the 8kHz is much more audible. Wouldn't the implementation of A-weighting filter tend to make the 8kHz noise more prevalent in the FFT?
Any suggestions on this topic are appreciated.
Thanks!
(2,433 Views)
Hi David,
If you want to enable the enhanced alias filter, you can use a DAQmx channel property node. I would recommend placing a DAQmx Channel property node on the block diagram and then going to Analog Input » General Properties » Advanced » Enhanced Alias Rejection Enable. See if that works and let me know.
Jake H | Product Manager
(2,412 Views)
