source code
I have an application that was made for me in labview. I have paid for it and the program works well, I need to know if I should be recieving source code with the program so that I can alter it in the future.
thanks john
(4,321 Views)
hi
that should be decided in the contract you made with the provider.
N
(4,317 Views)
thats what Im doing. do I need source code or is the program built so that it can be manipulated from the end users code?
(4,311 Views)
As Nitad said, that is determined by you and the provider you contracted.
Contact them.  We can't answer that question.
(4,292 Views)
Once the executable is built, you can NOT extract the source code from anymore.  So if you do want to modify the program at some point, you WILL need the source code.  So YES indeed, you have to agree with your software supplier that source code becomes your property @ delivery and acceptance.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,283 Views)
That depends on what you mean by manipulated. Like any .exe build in C, C# or LV it can support alot of modifications and ini-files and the like if built around it. If you want to change how the program works in the core you'll need the source code. That's the same for all programming languages.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,274 Views)
