space of string
Hello all...
I have an array of strings. In each string got 2 words there. These are separated with tabs. But now I want to get these words separeted in a string indicator. Is it possible?
with regard
Jaxx
(3,125 Views)
Hi
One of many ways to do that is attached.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,121 Views)
Hi lan F K,
Sorry for confusing you. What i mean is not seprate those words to different string control, but in one string indicator only.
Because when i read those "words" to a string indicator from my program, i found that "tab constant" useless while display in a string indicator. Some more, "words" i have is actually 16, so i need to do 15 "spaces" between them.
Hope for help
with regard
Jaxx
(3,102 Views)
Use "search and replace string.vi" from the string palette.
  • Search String is "\t" (set the string diagram constant to display '\'-codes first)
  • Replace String is " ", a space character.
  • Wire a TRUE to the "replace all?" terminal on top.
    That should do it.
  • 0 Kudos
    (3,095 Views)
    Sorry for late reply... as Altenbach suggested...
    Realized as attached VI.
    Cheers!
    Ian F
    依恩与LabVIEW
    (3,090 Views)
