special characters
How do I insert special characters in a string? For example I'm trying to insert the hex equivalent of 0x01, 0x04, and 0x00. The hex data is being sent over through a serial connection and the device I'm sending it to needs the data in this format.
(3,839 Views)
Accepted by topic author NickBl
(3,837 Views)
Not sure exactly what you need, but you can use "format into string" for a lot of your string constructing needs. The specifier for hex is just "%x" but we can pad it with a zero using "%02x".
(3,828 Views)
Okay thank you gregoryj and HopeH. I'll add that into my code.
(3,752 Views)
