specified timestamp occurs after the end of the limit
I am trying to implement the Limit Testing VI, using the Limit Specification VIs to define the upper and lower limits, into a waveform graph.The Limit Specification VIs don't accept a timestamp from the waveform t0 directly, and will only accept this parameter if converted to a DBL as per one of the NI examples, i.e. the Limit Testing Measurement one. However this only seems to work in the example because it is a zero timestamp. When I try it with an actual timestamp, I get error -20337 'specified timestamp occurs after the end of the limit'. How can I resolve this?
(3,580 Views)
Hi DLTD
Using an actual timestamp will give you a value for x0 of 9.354E+9. To avoid the error, the limits in the limit cluster have to be two arrays where the x0s are in range of 9.354e+9. I am not sure how you create them, as this part of the program is missing in the screenshot, but what I can see, is that you are giving scalars instead of arrays as limits.
On the other hand, I just tried it with good input values for a real timestamp. I didn't get an error message anymore, but the VI got stuck somewhere else. Changing these VIs to accept real time stamps looks quite time consuming, so I think it is easier to change your waveforms to start at 0.
Andreas Jost
Andreas
CLA, CTA
(3,519 Views)
Thanks for the response. I've achieved the desired outcome using masking, as demonstrated in the Mask and Limit Testing of XY Graph example, which actually worked very well.
(3,513 Views)
Hi DG76,
I have a same problem like you. I have DAQmx task - time window 100ms (1000 samples) and like you, when using t0 I get an error -20337.
Please, how did you solve this problem?
Thank you
Best regards
Real1ty
(2,392 Views)
