specify a relative path with "write to measurement file"
How can I specify a relative path with the express VI "write to measurement file"?
It seems that it only accepts absolute paths as input.
Thank you
Message 1 of 11
(5,760 Views)
Relative to what?
In short, you have to take your relative path and use Build Path in order to create the absolute path.  Here's an example using a relative path from the current VI's path.
GCentral
Message 2 of 11
(5,758 Views)
Sorry, relative to the folder where my labVIEW project is saved into
Thanks for the reply
Message 3 of 11
(5,751 Views)
That's actually easier
GCentral
Message 4 of 11
(5,744 Views)
Hi, I have a similar question - how to specify a base path with "write to measurement file"? I want to set a base path for "write to measurement file", and let "write to measurement file" itself to define the series of files name. Is it possible? Thanks~
Message 5 of 11
(5,376 Views)
Why don't you add a timestamp or something that means something to you at the end of the file?
Message 6 of 11
(5,370 Views)
That's exactly what I am trying to do. My thought is: firstly give it a base path, which is chosen by a higher level operator, then give it a relative path, which is chosen by a lower level operator, and then the series file name is defined by time stamp. And is it possible to define the base path by wiring it to "filename", and define the relative path and file names in the dialog box? Thanks~ Now what I did is to build the path first (combine base path and relative path/file names together), then wire it to the "filename".
Message 7 of 11
(5,341 Views)
If you already know how to build up your path then I do not see the issue. Express VIs would have to do the same thing inside if there were a "relative path" option, but it sounds like there isn't. If it is just taking up too much space on your block diagram, you can always put it in a SubVI yourself. Was that your main concern?
Message 8 of 11
(5,334 Views)
Yes, I agree with you - there is no relative option here, so I have to build the paths first. My concern is simple, I am just curious about how to write a relative path directly into the "write to measurement file". Anyway, thanks a lot for taking time answering.
Message 9 of 11
(5,302 Views)
Write to Measurement doesn't look for a relative nor an absolute path.  It looks for a path.  You simply wire a path in.
You can choose to use an absolute or relative path to do this.  Have you tried using the relative path snippet posted just before your reply?  If that works for you (and it should), all you need to do is replace the "relative path" piece with with string you build.  You can make this string however you please.  Timestamps are a good choice.
Where exactly are you stuck?
Message 10 of 11
(5,297 Views)
