spectral analysis with 10 averages using 10 lvm files
Hi
I would like to create a spectal analysis of some results i have saved in lvm files in labview 7
is it possible to use the averaging option in the spectral measurement function to do 10 averages if i read 10 lvm files
ie.
Read lvm file #1
do spectrum analysis
read lvm file #2
redo spectrum analysis and average results between file #1 and file #2
read lvm file #3
ect
Thanks in advance
Mark Thompson
(2,506 Views)
hi there
you can swop the order of calculating the average and the FFT. So first read all lvm files, average the time based data and then do the FFT over the averaged data.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,494 Views)
