spectrum analysis
My problem is that I am taking in a spectrum ranging from the UV to the optical parts, I need to be able to be able to choose a small part, a window of 10 to 20 nm, and get a polynomial fit and differential display for the signal in that window. I have it running that it takes in the spectrum and saves after each exposure time to an excel file. Would someone be able to help me.
(2,700 Views)
You can do the fitting directly in LabVIEW.
Simply extract your xy-data using e.g. "array subset" and feed it to "General Polynomial Fit" (and also specify the desired polynomial order).
If you get stuck, attach your VI and we'll help you. :).
(2,684 Views)
