speech comparison
Hello, Im trying to make a VI that compares a speech input from a microphone to wav files in a folder. If the input speech matches any of the wav files in the folder it will output a specific text. I'm trying to implement this using Neural net but im stomped. HELP! Thanks 😄
(3,111 Views)
Can you post the code you came up with and explain what you could do, what you couldn't do, etc...
If you go into Help > Find examples... > Search tab > search for "wav" you'll find "Recored Wav File.vi", maybe this will help you.
As to how to compare / match the WAV files... I'm sorry I will be of no help for that. Just use Shazaam Smiley Very Happy
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,110 Views)
TiTou,
Is it possible to make a list in labview where all the wav files are stored?
(3,103 Views)
