speech recognition by labview and Arduino
Hello Moha,
Don't you always need some kind of algorithm to recognize anything? 🙂
What would you like to do exactly and what would you like to avoid?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 16
(2,104 Views)
Hello CThierry
Actually I need Control robot with voice, so I need in labview make something to recognise the voice and then using that command to control the robot.
Message 12 of 16
(2,102 Views)
Hello moha,
This  Community article would be a good starting point:
https://forums.ni.com/t5/Example-Code/Voice-Recognition-using-Advanced-Signal-Processing-Toolkit-usi...
Kind Regards,
Message 13 of 16
(2,096 Views)
You can use the built in .net or activeX voice components like system.speech assemblies.  Use this to get your voice recognition, then send simple commands to the microcontroler.
This is simplier than rolling your own voice engine.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 14 of 16
(2,094 Views)
How? can you guid me please!!!!
Message 15 of 16
(2,092 Views)
Hi moha62
I would say the simpler way to conduct voice recognition is by using App Inventor built in voice recognition system. The communication between Arduino and App Inventor can be by using bluetooth or wireless. Plus there are already plenty of code online. Take a look at the links below and hope it helps:
http://appinventor.smartphonedaq.com/speech-recognition.page
http://appinventor.mit.edu/explore/stories/voice-controlled-arduino-beginners.html
Message 16 of 16
(1,806 Views)
