speech
Respected sir,
I am studying the formant synthesis in speech production system. While navigating through the internet I found one VI on formant synthesis. I tried to rebuild that VI but I could not understand that VI and stuck up at two three points.
http://cnx.org/content/m15459/latest/ this is the link where you will find the video under the heading "formant synthesizer" in which the working of the VI has been explained.
I am sending the VI which I have built file named "block_diag" is the main VI and two pole reso and blp are the subVIs used.  Please see the files attached here and please tell me where I am doing mistakes. Sir, I hope you will help me. I request you to please tell me my mistakes. I will be very grateful and thankful to you.
Waiting for your reply.
Thanking you.
Pradeep
(3,355 Views)
You need to zip uo the whole project and post that...you are missing a few things...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,324 Views)
