speed of data comunication with rio/compact fieldpoint
How fast can a loop be between a pc and a compact fieldpoine or compact rio?
Lets say I need to transfert 200 bytes in both direction?
Can a loop time of 10 msec be realized?
What is the time limit? 1msec? 10 msec? 100msec?
What is the jitter on a tcp/ip transfert between the units if the network isn't shared.
Woutert
Have program a realtime simulator for powerplants written in C++.I translates the RT sim to NI components and software (Labview).
My rt pxi turbine simulator for simulating grid incidents was succesfully used in a nuclear plant in 2006.
Look at http://sine.ni.com/cs/app/doc/p/id/cs-755
Message 1 of 9
(3,348 Views)
Hi
My experiance with cFP is that it is quite slow. You can forget about real time. First of all due to TCP/IP and second due to actuall slow rate between cFP and PC.
Undortunatelly I can not give you a number. I have not measured it.
cheers
Pawel
Message 2 of 9
(3,327 Views)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 3 of 9
(3,319 Views)
hi there
here's a benchmark for a LabVIEW RT Application on a cFP 2020  target:
TCL (Time critical Loop):
 8 ch AI
 8 ch AO
 8 ch DI
 8 ch AO
some math incl.
 - scaling AI -> Publish Write
 - de-scaling Publish Read -> AO
 - a little bit of calculations
NPL (normal priority loop (NPL):
~10 Items Publish Read
~30 Items Publish Write
GUI (access via RemotePanel for Configuration)
Access to the published Items on the PC via FieldPoint OPC
Cycle Time of the time critical loop (TCL): < 10 ms
i strongly recommend LabVIEW RT 7.1, because i observed some real improvements in performance since LabVIEW RT 7.0, especially concerning the publishing. the programming requires strict usage of the RT programming techniques (TCL, NPL and subroutine FGV for datatransfer between the loops.  see the RT bookshelf for more info.).
Best regards
chris
Message 4 of 9
(3,319 Views)
hi there
 8 ch AI
 8 ch AO
 8 ch DI
 8 ch AO
 some math incl.
Best regards
chris
Message 5 of 9
(3,318 Views)
Best regards
chris
Message 6 of 9
(3,317 Views)
hi there
 8 ch AI
 8 ch AO
 8 ch DI
 8 ch AO
 some math incl.
Best regards
chris
Message 7 of 9
(3,318 Views)
i'm sorry, i hit my keyboard to many.....
Best regards
chris
Message 8 of 9
(3,316 Views)
My experiances from the past.
In 1985 we have build using a intel 8080 3MHz a digital io interface. It used a GPIB interface and we were able to do 300 loops a second for reading 32 analog inputs, 18 analog outputs, 8 digital inputs and 8 digital outputs. The results were transfered over a GPIB interface each 10 msec.
Now almost 20 years later, using a 200 MHz 16 bit processor it is still hard to do the same.
Where is the bottleneck?
Message 9 of 9
(3,310 Views)
