05-14-2008 08:57 AM
05-15-2008
06:15 PM
- last edited on
07-22-2025
03:24 PM
by
Content Cleaner
Hi pagauthier,
Unfortunately, there is no information available on the noise specifications for the Speedy-33. However, there are some great resources about noise considerations:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/analog-fundamentals/dithering--...
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
If you are able to determine the frequency of the noise, that might help locate the source. You'll also want to make sure there are no grounding issues with your signal.
Eric C
05-16-2008 11:36 AM
05-16-2008
02:18 PM
- last edited on
07-22-2025
03:25 PM
by
Content Cleaner
You could try generating a tone to offset the noise that the board produces. Use the Tones and Noise Waveform.vi to produce an output signal that offsets the noise.
Eric C
05-16-2008 03:00 PM
05-17-2008 08:11 AM
05-19-2008 04:10 PM - edited 05-19-2008 04:11 PM
05-19-2008 05:47 PM
05-19-2008 11:14 PM
05-21-2008 09:18 AM
