speedy-33 maximum DSP capacity
I am new to Labview and Speedy-33. We currently working on a small project using biquads on the Speedy-33. For the moment, it work perfectly. Ideally, I would need 48 biquads to implement stereo octave band filters. I think that the DSP capacity limit is more about ~18 biquads (with a sampling rate 36kHz), at least according to my experience. Using 18 biquads, I think that I get some glitch indicating the max DSP capacity?
Does 48 biquads seems impossible on a single Speedy?
What would indicate me that I am exeeding the DSP capacity at 36kHz? What is the biggest filtering operation we can imagine on a Speedy-33?
Also, what may reduce my capacity is that use a table to store my coefficient. Maybay the routing of this table (with supplementary "index array" to extract the proper coef) consume even more computing time?
Thank you,
(2,290 Views)
Hey Pagaauthier,
You might want to move this thread to the DAQ forums. You will have a lot more response there.
Thanks!
Aashish M
CEO
TransferFi
www.transferfi.com
(2,270 Views)
