split 1D array
hi, i have  Decimals array , when i use split 1D array functions,change  numbers after the decimal point. What to do to dont change them.
Message 1 of 9
(5,001 Views)
HI,
Could you attach your code?
because I don't have that problem. I am using LV 2010
Message 2 of 9
(4,974 Views)
Looks wiered. Which LabVIEW verison are you using? I don't have problem in 2012 SP1.
Message 3 of 9
(4,944 Views)
2013, thanks
Message 4 of 9
(4,936 Views)
Without seeing code, I'm guessing you have wired the outputs to arrays of integers?  If this is the case, change the element of the array representation from integer to double.
Bill
CLD
(Mid-Level minion.)
Message 5 of 9
(4,931 Views)
Why would you say thanks and not attach your code? No one here are mind readers.
Message 6 of 9
(4,914 Views)
Please stop offering posts that have no value.  If you want help, help us help you.  Post your code.  You're clearly doing something wrong as nobody else has this issue.  We can't figure out what YOU'RE doing wrong until you show us what you're doing.  Below the reply there is a big bold word: "Attachments"  Beneath that is "Browse..."  Click the browse and add your vi.
Message 7 of 9
(4,911 Views)
Well, in another post he actually did attach code so he clearly knows how to do it. My conclusion is that he doesn't want to for some odd reason.
Message 8 of 9
(4,892 Views)
Most likely your output array indicator uses different formatting. Change the formatting to show more decimal digits. (right-click array element...display format...)
Message 9 of 9
(4,888 Views)
