split date time string when in array
I am reading in an array of time stamp strings, from a file. I need to split each element in the array into its respective time string and date strings.
(5,826 Views)
What do you want your output to be like?  Two arrays or a 2D array, with first column being time and next column being date?
- tbob
Inventor of the WORM Global
(5,806 Views)
I wasn't sure what you wanted, but here's my guess.
In the "Experiment#" Value Change event
add this code
LabVIEW 5.0 seems so long ago...
(5,793 Views)
tbob, I wanted 2 arrays, so that I could write them to 2 combo boxes. I think I figured it out though, by indexing the array and sending the indexed column to a auto-indexing for loop with search/split string. thanks, for the quick reply though.
(5,783 Views)
