split front panel into 2 parts
Hi
I need to spli the front page into 2 parts.On top I need to put a question with picture which are fixed and on bottom a page with scroll to go up and down I would like to put all my indicators and controls in that part but as I said the top part should be fixed and no one go up or down by the scroll of bottom page.
(5,953 Views)
In the Containers control palette is a function that will provide exactly what you want: Horizontal Splitter Bar.
If you cant find it, use the search button on the palette or use the LabVIEW help.
(5,945 Views)
Sounds like you are a candidate for a Horizontal Splitter Bar.  Look for it on the Containers subpallete.  You can then have separate regions with or without scrollbars.
Edit:  What he said.
(5,944 Views)
Use the splitter bar on the Container palette.
Edit-what they both said.
(5,941 Views)
really sorry for my late reply
many thanks for your help
just I have a problem.I have splitted my front page into 3 sections .In one section I put a waveform Graph the in the properties of the control I have selected "Fit Control to Pain" so the scroll bar for that pain disappered then I saved my file
after that I have made many changed and now I would like to have scroll bars in that pain again to scroll vertically and have many waveform graph controls but it is not possible and I cant get back scroll bars.Would uu please let me know is it possible to have scrolls for that pain again or I have to do all the design again.
Many thanks
(5,885 Views)
Place the cursor over the splitter bar (you'll see the cursor change), right-click and select Upper or Lower Pane depending on your situation, then Vertical Scrollbar -> Always On.
(5,867 Views)
