split signal not showing multiple outputs
I am trying to split the multichannel signal received from a NI-6008 DAQ. When I connect the data to the split signal vi, there is only one output eventhough i drag it dow to give me all the outputs.
Please help its urgent.
(2,728 Views)
Accepted by topic author koolshyam@aol.in
What version of LabVIEW are you using?  Can you post your VI?
If I remember, one of the versions of LabVIEW had a bug in the way the split signal function would work.
(2,726 Views)
