split string to the required pattern
Hi guys,
I have an array of input string for example "P?\.?" I need to split it into an array as
index 0=P
index 1=?
index 2=\.
index 3=?
(I.e if its a "?" I have to store it in a different index and if its "\." I have to store in a different index.
Please help me with this?
also attached and vi which I'm working on.
Message 1 of 8
(2,713 Views)
Was about to say that this is insanely easy, then noticed the dot after the backslash. Give us a couple other example strings and expected outputs.
What if the input string is "P?/.?" (forward slash)? What if it's "P?.\.?" (extra dot)?
I'm working in 2017 so I can't open your VI unfortunately.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 2 of 8
(2,682 Views)
Thanks for the reply.
there won't be any forward slashes.
below are few examples of the string
P?\.?
REL?\.?\.?
P??\.?
(i.e  "\." are always together and with the same order and same type.)
Message 3 of 8
(2,675 Views)
P?\.?
REL?\.?\.?
P??\.?
What are the expected outputs of those examples?
I'm gonna guess:
"REL?\.?\.?" --> [R, E, L, ?, \., ?, \., ?]
"P??\.?" --> [P, ?, ?, \., ?]
That right?
Redhawk
Message 4 of 8
(2,656 Views)
Yes it is right.
but I want keep the starting string combined in the first index.
i.e (REL?\.?\.?)   =>>> OUTPUT ==>>(REL, ?,\.,?,\.,?)
Message 5 of 8
(2,653 Views)
Yes, could you help with this?
Message 6 of 8
(2,634 Views)
Accepted by topic author tars364
Lot of different ways to do this but this is the first that came to mind.
Redhawk
Message 7 of 8
(2,627 Views)
Thank you
Message 8 of 8
(2,623 Views)
